Hi guys
Just thought I would check if anybody knows of any commen problems with the PDC on an SL55. Whenever mine is active (not turned off on the button) there is a 2 sec beep and both front and rear displays shows two red lights before eventually turning itself back off on the button. I am guessing the fact that it is both displays, iw is more likely something like an earth fault, as I presume a faulty sensor would only show on the relevant display (fron or back) Any thoughts, or common areas to look would be appreciated
Dan
Dan
