sl60 amg 129 suspension fault
MB TECH WARRINGTON
any help appreciated here,
sl60amg, hydraulic suspension,
bouncing all over road when driven, vehicle lowers and raises, level ok, no faults in system, all strut levels reading correct, pump seems fine, oil flowing well,
i know in the new suspension systems on newer cars this fault can be caused by dirty oil causing valves to stick open in valve blocks, so before we change the fluid just checking if anyone has experienced this fault, and can point me anywhere, its a rare car with rare suspension on the 129,
star
Reading
Smart + others :)
I expect the spheres have colapsed. done a set last month.
Richard Moakes
Newton Abbot, Devon, UK
CL500; ML500
Having recently dealt with ADS on my R129, I concur with star, the most likely explanation is the spheres have failed.
Is there any suspension give at all, bounce test etc... ?
MB TECH WARRINGTON
MB TECH WARRINGTON
no its solid, knocks your teeth out whilst driving,
not fully conversant with this suspension system,
star is there a sphere on each strut? did you replace all 4 if so? thanks for pointers anyway,
Richard Moakes
CL500; ML500
Four spheres, two in the spare wheel well, and two behind covers in the front wheel arches.
Easy enough to change, just watch out for corroded pipes and rounding off the fittings. From what you describe some new spheres will solve the problem, everything else appears to be working.
I have a .pdf of factory information about ADS 1 on R129 chassis, it's in German, but you are welcome to it if you want it? PM me your email address if you would like it.
Cheers,
Richard
piestore
manchester
ads 60 129
HI definatley sperhes as per other comments on this it is nothing like abc or airmatic
BlackC55
South coast
C43
I agree with all the above. I am doing as set friday. Be very careful around the area of the front arches as the ADS electronics under there are sensitive to such things as hammer blows. I have a load of documentation (in german on these)
MB TECH WARRINGTON
MB TECH WARRINGTON
thank you everybody for info, ive recieved the german docs and scanned over, going to get the car in for repair very soon, going to fit the 4 spheres, ill keep you informed of my progress,
Richard Moakes
CL500; ML500
No kidding, the accelerometer on the front offside control arm and the front nearside inner wing is VERY sensitive, and even more EXPENSIVE :(
