Slack spacesaver wheel?
Beemer2
South Lanarkshire
2014 E250 petrol W212
On replacing the jack kit of my E250 W212 into its plastic carrier I noticed that the carrier wheel does not spin down sufficiently to clamp the spacesaver tyre. The wheel cannot jump out but I can lift it 0.5" inch which means that it can clunk when travelling on a bumpy road.
Has anyone else noticed this?
Have you tried turning the wheel upside down
JonnyCJ
ML350 Grand Edition 2011, ML350 Sport 2010, VW Splitscreen 1965
On replacing the jack kit of my E250 W212 into its plastic carrier I noticed that the carrier wheel does not spin down sufficiently to clamp the spacesaver tyre. The wheel cannot jump out but I can lift it an inch which means that it can clunk when travelling on a bumpy road.
I must admit - I haven't. However, I haven't been in your car either so it's hardly surprising !
Beemer2
Beemer2
South Lanarkshire
Jack kit fits in the centre of the plastic carrier wheel so it cannot be reversed. I just checked again and there is no way that the carrier can be screwed down low enough to grip the wheel. I'll place something on the wheel to take up the space
I would think then that the wrong screw for holding it down has been supplied
JEZ.S320L
Costa Calida, Spain
www.latorreonline.es
Lincoln Navigator and a S320L Business Edition
Would your wife, friend or close family member, sit on the wheel in the boot to ensure the wheel doesn't rattle over any bumps until such time as you find a more permanent solution?
Just a thought.
Beemer2
Beemer2
South Lanarkshire
Just a thought.
I've decided the best solution is to flood the wheel well with water and to connect a thirst tube up to the side of my headrest. Sorted!
