Hi.
I am trying to get behind the door card to refix the window runners (or whatever it is that has come loose in there) and am having real problems.
I have found the 3 main screws (2 behind the door handle and the other behind the SRS badge in the door), but I cannot for the life of me work out how you lift the door card clear when the whole thing doesn't seem to want to seperate from the chrome door opening handle.
I have removed the lock mechanism plate and the chrome panel at the top of the door, but still it is stuck fast where the door pull is. :-x
It seems to be screwed in from behind, but I cannot get in there to loosen these screws. :???:
Has anyone removed an SLK door card before? If possible some step by step instructions wouldn't go a-miss.
I want to get this done myself, so I don't have to pay dealer rates to do what must be a very simple thing if you know where all the clips are.
When I pryed the bottom edge of the door off, a 10mm nut fell out and I would hazard a guess that is what needs retightening to stop the window rattling in the door.
Any and all help greatly appreciated.
Cheers,
Dan.
Cheers,
Dan.
