SLK 2005 Rear subframe replacement
PROJUMPER
Mercedes
Has anyone fitted a rear subframe on a SLK?
How long did it take?
Anything to watch out for?
ETC?
Many many times!!! Straight forward nuts and bolts job, the handbrake cable clips need drilling out and refitting on the new frame with rivets! Perfect time to clean the brake pipes up once the frame is out!
Uncle Benz
West Sussex
Mainly Mercedes
Be aware it is heavy. You can’t remove the differential first because the rear mounting bolts are shrouded. If fitting a new one I paint them first as the factory paint is little more than a token gesture. Spray some cavity wax inside via the holes too. You’ll need a four wheel alignment after. Nine times out of ten the bolts are seized on the toe adjustment arms, so budget for new arms and eccentric bolts. I can swap one over in a morning, but I do have the benefit of a two post lift and a decent pit jack
Roger Jackson
Isle of Wight, England
SLK 230K R170 2001, GLC 220D 2015
My Daughter is thinking of buying a C2005 SLK... is the subframe an issue to look out for?
Also, does the R170 have the same subframe issue?
R170 rust in quite a lot of places... Some R171’s have the issue others don’t. Have a look underneath when test driving
Uncle Benz
West Sussex
Mainly Mercedes
The 171 and 204 are the most common for rotting rear subframes. 170, 202 and 203 are much less affected. They changed something. I think the material is thinner.
P
PROJUMPER
Mercedes
You can't see the area which is worst affected by rust by lying on the floor, the car needs to be on a ramp!
davidsl500
Home : Derbyshire at the moment !
R172 250CDI Gone..!, R129 SL500 Gone...
Mr Pedantic here ; you can't look underneath when driving - unless you are driving over a camera...or you put it into drive, get out and let it run you over......:rolleyes:
Fair point well made, although Brian Harvey managed it...:eek:
