SLK 230 - Locked out
AndrewCardiff
Hello
I have a large problem with my 1999 SLK 230 - I can't get into it!
Key fob and spares have been given new batteries but still won't unlock to central locking.
Also the key blades won't turn in the locks, despite plenty of WD40
Mercedes in Cardiff told me to smash a window!!!!
Any suggestions gratefully received.
Andrew
A
AndrewCardiff
  • #2
Hello all,
surely someone knows the solution.
What about Malcolm?
I did see your post last night, but I had my own problems (ex) I will see what I can find in the day
Can you put up the 6 first VIN numbers
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Hello
Andrew
Had a similar problem with a BMW that I use to own, turned out to be a faulty central locking unit in on of the doors, apparantly is was burnt out and would not release itself or any of the other locking units. I was lucky enough to have access to some "special tooling" - basically a thin, flat metal blade with a hook on the end that I managed to pass down between the glass and the outer door seal and with a lot of persuasion managed to hook up the release lever in the locking mechanism. I'm not saying this can be done on the SLK, one of the "experts" will no doubt be able to advise you.
If you break the glass it will cost you about £115.00 and take about 2 hours to replace, plus lots of cleaning up! - I know I replaced a door glass last year on our 230;)
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Forgot to post this, it's the locking unit for your car...................
As there are only 2 170's I have had a look and it is the old fault of water in the boot shorting out the PSE pump, this in turns causes the locking not to work
You do need to get into the boot, as the battery may be flat owing to the shorting in the pump
The mod is to turn the PSE pump upside down, there are details here on this mod
A
AndrewCardiff
1st 6 numbers WDB170
Can't get into boot with the key either
I have already checked on both cars, there is nothing for the key that will not turn, I can help thinking are the the correct keys for the car, as this part is separate from the radio controlled locking
A
AndrewCardiff
Hello Malcolm
Is this a reply t my thread?
Andrew
Andrew, the answer to your fault is in post 6 water in the PSE pump, I have no information on the door locks if the Key will not turn other than drilling out the boot lock and getting a new one,once the problems in post 6 have been dealt with
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Hello
Andrew
Any progress on your problem??
Tel: 020 8863 9233
