SLK_
- Oct 4, 2023
- SLK 230 (R170 pre-facelift)
I'm a new member, but I've owned Mercedes for a long time and enjoyed owning my current 1997 SLK 230 Kompressor Auto for nearly 10 years.
Enjoyed it until recently that is... I have a problem that no one can fix and my garage suggested I join a forum for some advice as they are all out of ideas!
It all started a few months ago, when the supercharger suddenly stopped working on a long journey back from a holiday. It used to kick in at around 2000 rpm, now it only spins (slowly) over 4000 rpm. I took it to a respected Mercedes specialist who diagnosed on the 'STAR' machine a faulty Supercharger Clutch. My car is a early r170 model with a magnetic clutch. So, I replaced the magnet as suggested with a known working one. This, sadly did not fix the problem. Since then I have spent ££££ Replacing the following parts:
K40 relay (New)
Coolant Temp Sensor (New)
Cam Sensor (New)
Crank Position Sensor (New)
All supercharger hoses (Mix of new and good used)
Lambda Sensor (New)
Cat converter (New)
PCV (New)
The result of all this is that the supercharger still does not kick in at the correct rpm, but now I have another issue as well ! If I drive the car hard in manual mode or use the gearbox kickdown. Then the car will not start until the battery has been disconnected for a few minutes.
I've taken it to 3 garages in total and I am just desparate to fix it, because I really like the car.
The codes on the STAR machine are P0443, P1525, P0805, P0806 and P0135.
I really hope someone can help? I've had the wiring checked for oil and there is none. I've also had a new 'MOSFET' soldered on the engine ECU.
Thanks in anticipation, Katie
K40 relay (New)
Cam Sensor (New)
Lambda Sensor (New)
Cat converter (New)
PCV (New)
