hi ihave a slk 280 0n a 2006 plate,the passengers door will not lock?the drivers side is ok.is there a fuse?or is it the keyfoob.any help please.i can push the door lock plunger down to lock the door in the mean time.
The door locks are air driven by a pump in the boot. Do you hear a pump run for about 20-30 seconds when you unlock the car? If so you have an air leak on the line to that door, possibly a failed actuator.
d:class automotive are specialists in automotive interiors and upholstery. From Mercedes and modern cars to custom and classics. Tel: 01483 722923
Email:info@dclass.co.ukWeb:www.dclass.co.uk
