Slk 320 2002 Non starter
paulwith
My 2002 SLK will not turn over.
Battery is checked and fine, all lights and dash lights fine,but no contact.
Strangely the cooling fan cuts in after a few second although the engine is cold.
Green flag guy suggests an earth fault or inhibitor switch on the gearbox.
Also read suggestions of a relay.
Any thoughts please before I recover to garage.
Thanks.
PS I can't hear the fuel pump with ignition on, clue?
Flyinspanner
Ruislip
Wiggle your gear selector whilst trying?
star
Reading
Smart + others :)
Sounds like the aux fuse board with the k40 relays, under screwed down cover ns under bonnet.
star
Reading
Smart + others :)
I’d just replace or open up board and check for dry joint.
P
paulwith
Thanks Star
Now I'm confused, I thought I would try again this morning.
Ignition on , fuel pump running, started first time!
On an off a dozen times, running perfectly.
Now what? Read the codes while I can get it to my indy? Does this confirm your suspect relay?
Any thoughts?
star
Reading
Smart + others :)
I don't think this fault will not show on any diagnostics, experience is the key. ;)
P
paulwith
What kept you!?
I have a good local indy, should I ask him to replace the relay?
If the fault was the gearbox inhibitor would the fuel pump run?
P
paulwith
Update,went to start it today no joy, what's going on? Temperature?
Ben Smith
W204/C-class/2012/2.1 Twin turbo diesel (C250)
Could be a bad contact on the relay or even a bad contact on the ignition switch.
Ben Smith
If you want to test the relay theory, swap one for another. Obviously swap it with one that’s not critical to starting the car.
That will prove if it’s that relay causing an issue.
P
paulwith
Thanks Ben
Good idea-but, I have just tied it again,fuel pump running and first time start!
So where do we go from here?
PS I suppose the key is just a key and doesn't contain a "chip"
I have another key
P
paulwith
My attempt at a joke because you replied instantly.
Any further suggestions, it failed this morning,then started,then failed, now started perfectly
Ben Smith
The key has a it’s own code and high is read by the transponder unit which will be around the steering column area. Once the key is read and the engine is started it won’t need to be accepted again.
I’ve had a similar intermittent problem in the past and it was the ignition switch, it was letting me start the vehicle every now and again then it would cut out after 2 minutes of running or the other scenario was it would drive absolutely fine and wouldn’t cause a problem.
It was a worn contact inside the switch.
So I changed the whole thing and it never caused an issue again.
It’s difficult to say which contact is letting you down, do you have an electrical drawing for this car if so I’ll take a look over it and see what else could be letting you down.
P
paulwith
Thanks Ben, if it's the ignition switch,what would explain the cooling fan running very fast with ignition on and no start?
star
Reading
Smart + others :)
Ok. The clue is in the fact that the fan starts up when the car doesn’t. It mean could the engine ecu isn’t powered up and the fan controller can’t see it and so powers the fan up to default setting. Now this a diagnosis on the net without seeing the car but I have seen this before.
star
Reading
Smart + others :)
P
paulwith
  • #19
Thanks again,re. the AC It's been inop. for some time, seems there is a leak,didn't bother to fix it yet. Clue?
P
paulwith
  • #20
Update, diagnosed by indy as K40.
Replaced with new. Runs fine.
Thanks for help.
