Aston Dabb
- Jan 5, 2020
- W212 AMG 2010 E350 CDI
Got a 2003 SLK230 with a 722.6 Gearbox in it that is losing gears when it’s warm (reverse and drive). Gears are fine when cold but always loses drive as it warms up; it struggles to drop into gear from stationary after around 2 mins of running, but does manage to drop in, and after around 4-5 minutes; the gearbox has nothing but neutral and park! We’ve had the gearbox out a multiple times to try different things (we’ve even put a new wiring loom from the G/Box ECU to the Gearbox onto it!). Been told by somebody to ensure that the oil cooler isn’t blocked and I checked that by blowing compressed air down one pipe and seeing what came out the other pipe, which fresh gear oil came out due to it only just being replaced, and to make sure it had enough oil in it, which it had! We took the gearbox out prior to this to check that the gearbox oil pump was operating correctly as somebody had also suggested that we may have sheered the two metal pins off that drive the pump from the torque converter when we replaced the torque converter due to us first thinking that was the issue, but we hadn’t sheered them off and the pump was operating perfectly. The gearbox has absolutely 100% got the correct amount of oil in it and that was confirmed by an MB dipstick oil check from cold and MB dipstick oil check at 80 degrees Celsius (Temperature according to DAS). There are no faults related to gearbox in any modules. Is there anything else we could check?
