SLK Door Handle change
Status
Not open for further replies.
JohnMBOA
Does anyone know if it is easy to change the door handles and if it is who could supply body coloured ones, in the UK. Thanks
Arnie
London
The body-coloured ones are just the same as the black ones, but painted. You can get some from MB and then paint them. Or, otherwise, paint your existing ones.
You will need a paint primer for plastic trim and then the base- coat and top-coat. Of course you will need to remove them first.
The spray paint is also available from MB in small spary cans.
JohnMBOA
Removing door handles from SLK
Thanks for the reply.
Has anyone any advice for the method of removing the door handles?
Status
