SLK mirror indicator bulb replacement
Kylinski
cardiff
SLK R170 230 (2001)
Hi all :)
I need to replace my mirror indicator bulbs. There appears to be 3 bulbs in each mirror and 2 have failed on one mirror.
Don't suppose there is a 'how to' on changing the bulbs?
Though I am thinking that my last attempt at bulb replacement (climate control - centre console) cost me nearly £80 so maybe I should let the pro's sort it! lol :)
Kyle :)
The bulbs are sealed in and you replace the complete lens circa £18 from MB I have the instructions that you can have
Kylinski
Kylinski
cardiff
SLK R170 230 (2001)
Thanks Malcolm
I have sent both types and they should cover doing it, you can edit out your address
They have not bounced back do do check your junk box as they all have attachments
Kylinski
Kylinski
cardiff
SLK R170 230 (2001)
Right you are. Thanks again :)
Logi
Registered
KILMARNOCK
SLK200 2002 2000CC
Hi, been lurking here and took this advice when replacing mine, though my local dealer took £24 for my SLK lamp. Then i found the bulbs are not sealed in and easily replaced......:(
Very sorry if this was the case, I fitted the same mirror to my 129, that had bulbs and it was sealed, there could be more than 1 version and I can point that out the next time
attachment.php
