sailorP
- May 19, 2008
- Location
- North Herefordshire
- SLK32AMG
Stopped the car yesterday after a good run out, and noticed an LED glowing faintly, on the internal motion sensor / tow- away protection switch. Faint glow equals low current flow & earthing???? Poked the switch a bit and no change, so decided I had better refer to the manual. Went to the boot to get the manual, and….oh dear…..a brand new one litre bottle of Demon Sheen, (which I bought from Halfrauds at Brabus R230 recommendation) was laying on its side, minus cap, and empty. How can that happen? Don’t Halfrauds check their bottle caps are on tight? I guess I’ll be checking everything I buy from now on.
So I emptied the boot of all the kit and tools, finding most things dry, but tell-tale signs of pink fluid in places (even inside the bubble-wrap bag containing the towing eye). Some of the cloth friction pads were still wet, but all the foam was dry. I pulled the PSE module out from its hole, and felt damp underneath. Unfortunately, the PSE module didn’t move out easily, and fearing that I would make the situation worse, I shoved it back whence it came, having dried underneath the module. My courage to fiddle with something I don’t understand deserted me, sensibly given my ability to break stuff by looking at it...I have great experience at breaking stuff without trying.
A couple of hours later, my alarm kept going off, so I went back to the car, turned off the alarm, and tried to lock the car using the key. I prised out the little plastic cap from the driver’s door lock, locked the door, but the central locking didn’t work. The fact that the alarm is over-sensitive, and the central locking is not working on the key, all point to the PSE module. Car is heading for Uncle Benz’s shop tonight, hoping that Gareth can remove, clean and dry it out without having to buy a new one.
It’s ironic that the PSE module didn’t fail because of moisture ingress through the roof/boot seals, but from a stupid bottle of stuff that was meant to keep it looking shiny……pride goes before a fall. And the car has been so reliable….it wasn’t the car’s fault, it was mine. Damn.
