- Feb 8, 2006
- Location
- Grange Moor
- R171 SLK280, Smart R451, Land Rover 110 County SW, 997 C2S, R1250 GSA TE 40th, CBR600FP
- Moderator
- #1
Noticed a puddle behind the drivers wheel
911 had the same issue recently… seals failing on the washer bottle - SLK coming out in sympathy…
No headlight washers on mine, but there is the spare white power connector for them.
You can see the dampness at the bottom of the pump where it is leaking.
Pump out and cleaned up and gummi pflege the grommet
Back together and noticed the leak is around the pump and not the rubber seal
Taken motor apart and you can see the corrosion.
New pump and grommet on order.
Quite a few leaves etc behind the washer tank. You can also see one of the scuttle drain tubes in the top right of the below picture. Cleaned it all up and temporarily back together (without wheel arch liner) whilst waiting for the pump.
