SLK wipers not working
Qwandy
The wipers on my partners SLK have stopped working, fuses seem ok. Can anybody help please?
Also unrelated but when I lifted bonnet to check fuse the bonnet refused to lock and stay up, last time I opened it there was not a problem.
I will see what I can find on this.
Re the bonnet, push the handle forward in the car and the bonnet will close
Q
Qwandy
S:K wiper and bonnet
I think you misundestood the bonnet problem, it will go down ok but it does not stay up by itself, I have to prop it up with a brrom handle to stop it falling on my head.
Wipers still not working, can you advise where the relay is located for wiper motor?
Andy
You have the stalk switch and the N10 relay box and the wiper switch feeds in at pins 63 and 65
They are fused by F32 in block C its 15 amp
Q
Qwandy
SLK wipers
sorry to sound so thick but the only bit I understand is that fuse is f32. Where do I find relay?
Thanks again
Andy
Q
Qwandy
Been told by the garage that it does not have a relay and the module needs changing at £700 is this correct??
Please help!!!
Dec
Ireland.
W202
Could you ask the garage specifically what do the mean by the “module”
Wipers need a relay to control the intermittent aspect of the wiper motor.
Just a shot in the dark here but there is chance that the wiper motor is running but the wiper blade is not moving, to check, with the engine off, and in a quiet place, turn on the wipers to intermittent and listen closely to see if you can hear the motor cut in, for 1 second, about every 5 or 6 seconds.
Also try this on normal speed.
Dec
inverlass
New Registration
W170 SLK 2000 320
I am a Newbie. My wipers, remote locking and roof on my w170. have quit working. I will post more about how I get on with this.
MB star C3
DIS and and Xentry. software ASRA, EWA, WIS, EPC
Launch Diagun
Full wiring diagram.
Haynes Pro software
Hantek oscilloscope
Kelvin meter
Needs Lots of luck!
