SLK yes or no??
00slk
Cambridgeshire UK
I have been offered a 2004 SLK with 66k on the clock for a grand, spares or repair. Have no idea what model though.
The Missus came home with the information. If it were a r171 possibly worth it, buy the r170 I thought might be too much money.
EML on and instrument cluster no working.
Is it worth the punt?
Uncle Benz
West Sussex
Mainly Mercedes
If it’s an r171 it’s likely to be an m271 engine, which I’d avoid. If its an r170 the mechanicals are stronger, but rust likely to be the enemy. Take your pick ;)
For a grand it’ll probably break for more than the purchase price as a worst case scenario
As per above ^
2004 was the change over year from R170 to R171
00slk
00slk
Cambridgeshire UK
I'll ask the Missus to find out a bit more, what I do know is that it has had a new head gasket and timing chain.....at 66,000mls :shock: a complete set of new brake lines as well, so sounds like a r170?
Uncle Benz
West Sussex
Mainly Mercedes
If it had a chain at 60k it’s more likely an r171 with m271 engine. Chain and sprocket eaters
Chrishazle
Nr Ashford, Kent
Do more research before walking away from that engine - the early V6's were chain eaters, but AFAIK not other size engines. I had to do a lot of research before buying my R171 SLK280 - in Fire Opal Red, which could have been another problem - but was able to find that my engine is after the chain/sprocket problems, and the paintwork seems to be original and faultless (according to my local superb bodyshop).
A neighbour a few months ago paid a lot more than £1k for a R171 SLK200 that he's happy with!
The M272 V6 can have balance shaft issues, the M271 IL4 has chain and sprocket issues
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
We had a 2004 171 SLK200K did 90K miles in it nothing went wrong at all. Also had a 2010 171 SLK200K did 50K miles again nothing went wrong, except a new battery at 9.5 years.
There is an issue on a few 171's regarding the timing chain & sprockets, but its very low. Seems to occur 90K miles+ with a lack of oil changes.
Chrishazle
Nr Ashford, Kent
There's plenty of info on here and t'other side about which V6 engine numbers had problems - I know as 2 years ago before I bought my R171 SLK280 I had to do this research to find my engine number is well after the problem ones! Personally I would not look at an SLK with less than a 3L engine - 200's come with hair brushers and dryers in the toolkit!!:p:p:D:D
00slk
00slk
Cambridgeshire UK
Thanks Chaps for all the information, as usual the forum at its best :)
I will get some more info today hopefully and go from there, I do have a soft spot for SLK's, SL's and E Class's...........Ah what the heck......Mercedes in general :eek:
Careful buddy , your old buddy Wighty has an CLK200 :cool:
Chrishazle
Nr Ashford, Kent
When discussing potential SLK purchase with management, it quickly became obvious that "holding out for the V8" would first involve a divorce, making purchase of any SLK un-affordable!!:oops::oops::oops: Fortunately 3L was allowable as that was what I already had in the 968.
00slk
00slk
Cambridgeshire UK
Hmmm, he's treading on thin ice there Buddie o_O I've got an SLK200 too, darn cheek!! :p
Have you seen the prices of SLK's with V8's, more than the SL's, much more :shock:
Yes… I posted a few with the 5.5ltr engine in recently ;)
00slk
00slk
Cambridgeshire UK
  • #19
The low down is that this is an r170 SLK200
Vin WDB1704442F308992
Spares or repairs at a grand sound too much to me as I watched 2 r170's finish on the net for between £1200 and £1334 both in reasonable order.
I did pass on an SLK320 for £400 with an immobiliser issue.
If anyone is interested in this SLK I can quite happily inspect it for you or put you in touch.
If anyone is interested in this SLK I can quite happily inspect it for you.
Probably as rotten as a pear unfortunately :(
