mlc said:Thats a great bit of info Pascal, we also have a 97 230 SLK and just like Matty I have seen a huge spread of figures. We actually ended up trying to measure ours with herself holding the stop watch - and got 7.2seconds, however that assumed that the speedo is accurate.
Thanks again.
pascal said:Autocar tested it on 20-11-1996
SLK 230K (A) MAX SP: 140
...................0-60: 7.1
...................0-100: 20.0
...................60-0 : 2.6
They use sophisticated timing equipment like that used in motor sport
Pascal
mlc said:Matty - Go and wash your mouth out then write 100 lines of "I will not compare MG cars with MB's"!!
I am not an expert of the MG you mention, however just to confirm:
Does it have an electric hard top (which God only knows how much that weighs)?
Does it look perfect in a classic drop dead wonderful sort of way?
Is it a babe magnet?
Do strangers compliment you in the street when you own one?
More important - will it still be worth around 50% of its cost price at 7 years old - will it still actually work when its seven years old - its a Rover (sort of)!!!
I suspect (don't know) that the MG is manual - in the slk you point, press and hold on. In a manual to obtain the top acceleration you need 1. skills that most people dont have 2. to abuse the clutch / gearbox in a way that the owner wont want to do. also ask the MG owner what his 0 -140 mph time is - that should shut them up.
Bottom line Matty - we are the chosen few, if God drove he would have an MB. If one of your friends has the MG you just tell them in a knowing sort of way that one day they will see the light and join us. It works every time
Mark.
mlc said:David - A biblical argument, great!!
I thought the Triumph was Moses - "and the sound of his Triumph could be heard throughout the land".
May be wrong of course! However God or Moses - surely both matured and upgraded to MB's in the fullness of time
Mark.
Mark.
