Slow starting of engine
DonnaK
Cla200d
Hi all, I am.hoping you can help. I have a 17 plate CLA 200d shooting brake. It is taking quite a bit to fire up I think it may be cold damp mornings but seems to be getting worse? It's been serviced and MOT'd 2 weeks ago and was at Mercedes for a health check and plug in prior to that for a software upgrade. However the problem persists....... any ideas ???? Many thanks in advance
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Trouble with starting is normally either glow plug related or fuel.
Mr Greedy
Leicestershire
E350/2011/OM642 265bhp
Slow start on diesel can also be battery.
Are you able to give it a proper charge over night/when cold, then try starting it? It's a cheap test.
joderest
ML270 2003
depends on.... is it turning over slowly ? would indicate battery
Is it spinning as normal ? maybe fuel or glow plug related.
mioba
Nottingham and Köln
Glow plug or air leak or weak battery.
Test battery voltage / put it on charge would be first job.
Test Plugs.
A dying starter would be surprising, but as mentioned does happen.
D
DonnaK
Cla200d
Yes it spins as normal so thankyou glow plugs maybe a possibility!! Thank you
