Slow tyre Puncture
Bogus7430
W222 S Class
Hi All,
I seem to have a very slow puncture. It reduces by around 2 to 3 kpa per day. And decreases pressure more when at a standstill than being driven.
Now sorry if this sounds silly but just wnated to understand if repairing the tyre is safe as it is only 1k miles old.
I have a S600 btw.
Not concerned about the money but the tyre shop said they can repair the tyre.
Sent from my SM-N960F using Tapatalk
It depends on where the leak is coming from...
If you have a screw or nail in the sidewall then they won't repair as the patch can't handle the flexing.
If it's in the tread and over 20-25mm from the edge then they'll repair no problem.
You could also have a porous or cracked alloy or leaking valve
moj91
Northamptonshire
W213 E400d-T, W204 C250CDI-T, W220 S320CDI (AMG Kit), W168 A170CDI, W210&W124 OM606...
Get the alloy pressure tested, 50psi-ish (not over max of tyre) and dunked into a tank of water. if it is an alloy crack, a good specialist welder can usually repair for much cheaper than a replacement.
B
Bogus7430
W222 S Class
Thank you for the suggestions.Found the culprit. It was a nail.. Had to replace tyre.
vtaylor78
Northamptonshire.
E350 CDI Coupe C207 2010 \ SLK 250 R172 2011.
That’s a shame it couldn’t be repaired, but at least you have piece of mind now it’s sorted.
www.ckinsurance.co.uk
