Smell of exhaust smoke on ML-270 CDI
Mark A
Aberdeen
58 ML-320CDI.
I have noticed a few times lately that I can smell diesel smoke in the cabin of my ML. I have had a look outside & in th rear view, but cannot see any sign of smoke. Any ideas what could be at fault, and is it a cheap fix ??
Cheers,
Mark
M
Mark A
Aberdeen
58 ML-320CDI.
  • #2
Fumes in Cabin
Sorry, forgot to say. 2002 ML-270CDI with 62K mls.
M
Mark A
Aberdeen
58 ML-320CDI.
Parrot of Doom said:
Diesel fumes, or exhaust fumes?
Smells more like exhaust fumes.
C220GJS
Shotts, Scotland.
1995 W202 C220 Elegance
Check your rear door is closing properly.
If this is not the problem have your exhaust checked for leaks as a matter of urgency as exhaust fumes in a car is a very dangerous situation, never mind the cost get it done !!!.
M
Mark A
Aberdeen
58 ML-320CDI.
Not the door.
I will get it checked out. Cost isn't the issue, just need to know when I'm being ripped off by the local stealer.
Mark
Ultymate
N. Wales
C230K Estate 1998
Are you sure you've not been following another vehicle at the time and picking up their exhaust fumes via your heating/ventilation system:confused:
scotty2hotty81
there are some checks you can do yourself
1, take the engine cover off, make sure there is no black tar around the injectors (the seals are prone to failing)
2, while the cover is off look at the front of the engine, there is a square block, this is your diesel pump any leaks?
3, stick your head over the airfilter area if there is a stong smell and maybe a hissing noise possibly the seal on your first cat.
4, look underneath you car at the front any leaks?
Hope this helps
M
Mark A
Aberdeen
58 ML-320CDI.
It's booked in for Tomorrow, so I'll let you know. Dealer says it smells more like diesel.
M
Mark A
Aberdeen
58 ML-320CDI.
It turned out to be a leak on one of the injector pipes. Fixed now, everything now pressure washed, smell should soon dissapear.
Mark
Mark
Pleased you have it fixed, a contractor I used had his ML270 go up in flames on the M4 due to an injector pipe leaking and spraying fuel around the engine bay.
M
Mark A
Aberdeen
58 ML-320CDI.
:shock: Hopefully not a common problem.
www.ckinsurance.co.uk
