Smoke from engine
ksundeep
C230 Kompressor/2004/
Can someone please tell me what is the part marked yellow circle in the attached picture, I have smoke coming out from around it which then enters inside the car. Its a 2004 C230 Kompressor. Just curious to know what the part if before I take to the workshop. Thanks in advance.
ajlsl600
france
Looks a bit like oil filter housing. Put a socket on, it and see if, without force you can turn it clockwise. If so it's possible that the o ring seal is leaking and oil is dropping on heat source causing smoke.
Anyway get it checked out. If ti's oil filter housing you DONT want that spinning free.!
Oldspanners
Normandy
C CLASS 2004 C180
It is the oil filter housing, if you have had a oil and filter change recently there may be a badly refitted O ring and oil is leaking onto the exhaust. Don't ask how I know:eek:
Yes as above, do check this as it can be a large leak, very quickly.
K
ksundeep
Thanks. Any idea roughly how much it should cost - just a very rough estimate
To undo the top of the oil filter housing, check the O-ring and tighten it back up?
Absolutely nothing… ;) DIY…
K
ksundeep
Cheers !!
