I have a small, but annoying problem in my W210.
Well, 2 but one is so insignificant it doesn't bother me
1) when the gearbox is cold, it doesnt change gear until about 3000 revs, when i first leave in the morning, i drive the car in Winter mode, and am very light with the throttle, to allow the engine to warm up. But the gearbox wont change up, it just very very slowly increases the revs, i have to put my foot down some until it will..... When warm, it will change up at about 1300 revs if i am light with the throttle, so why doesn't it do it when it's cold. (the same happens in Standard mode too)
2) this one is slightly more annoying, When i put my foot to the floor to pull out onto the dual carriageway in the morning, the car will accelerate quickly and smoothly, the gear change perfect at about 5,000 revs. HOWEVER if i really boot it, the car doesn't change gear, instead it revs higher and higher (til about 6,000) then stays there, then about 3-5 seconds later the gearbox will snatch the next gear and lurch forward. I have learnt now to avoid this situation by letting off the gas so it changes up, then re-applying it. However i would like to fix it, if there is a solution.
Dan
Dan
