I can't find it now, but last week there was one set where you can adjusts the "focal length" by 4mm to get the light and your headlamps as best as possible, no idea if it works but the idea sounds interesting
it was 60 quid (for a pair) or so on ebay
Notes:
· Bulb compatibility follows the link http://www.sylvania.com/en-us/applications/automotive-lighting-systems/Pages/lrgmain.aspx
· Make sure it is the right type of bulb for your application before purchase
· If you choose H1 model, the diameter of mine is 3/8", pls make sure the stock socket can hold the H1 bulb. Otherwise it will require modification.
· Some vehicles may require resistor to stop flickering.
· The led kit is not suitable for the Germany car, for example: BMW, AUDI, Volkswagen, Mercedes-Benz etc.
· Will not fit the Car headlights with dust cover
· Will not work on day time running light bulb because voltage is too low to power up the LED.
· For can bus system, your model may require a load resistor to alleviate error message due to the low power draw of these bulbs,
Ah. I'd fit hid if I could be bothered to dismantle the headlamp unit and have all the ballasts and wiring inside.
Does the W211 not have self levelling suspension? No need for self levelling lights if so....
Can't post it here as not on the PC but the mot handbook does not say levelling washing systems are required. It clearly states that they MAY be fitted, and if so then they must work.
Current lighting regs say:
HiD lamps: levelers required.
LED lamps: levelers and wash system required.
All lamps >2000lm: levelers and wash system required.
New regs coming into force very shortly remove the distinction between lighting source and just focus on the luminous flux density (>2000lm).
Edit- none of this is to do with the MoT Test, but to do with the homologated car, i.e. the car platform that the relevant issuing authority for that particular country that has been approved. It's for this reason that "modifying" cars beyond what has been homologated for them (e.g. factory options) or in a way that performance won't be affected (e.g. go-faster stripes) is illegal.
This is the page from the MOT:
Vehicles equipped with High Intensity Discharge (HID) or LED dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system.
Where such systems are fitted, they must work; however, it is accepted that it may not be possible to readily determine the functioning of self levelling systems. In such cases, the benefit of the doubt must be given.
Method of Inspection
Where HID or LED dipped beam headlamps are fitted, switch on the headlamps and check the operation of any headlamp levelling and cleaning devices fitted.
Reason for Rejection:
A headlamp levelling or cleaning device inoperative or otherwise obviously defective.
So to me, provided the beam pattern in still correct, then HID would not fail an MOT. I dont want to blind other drivers.
The regs that you mention, are these for new builds or existing vehicles?
