Socket size
Its very important when tightening wheel bearings to keep the hub rotating so that the rollers do not make dents in the cages.
Leave the wheel on and spin it while doing up the nut so that the wheel slows and then back off a touch.
47p2
Scotland
W638, W140, W220, W639 All gone but not forgotten
I think it is 32mm
Ellsy Tanners
Mars
I thought that it dosent need a socket, the nut is locked with a 5mm allen key and the spins off, i might be being thick!!
Yes correct to undo the lock clamp, then a spanner
wireman
lancashire
Finger tight should do it.
