sounds from the car.
stevegbr
Mercedes-Benz C Class w204 C280 sports a
Few weeks ago i went over speed bump and heard what sounded like my exhaust had broken and was banging on the floor, took it the garage who then told me the exhaust was in perfect working order just a bit of surface corrosion, they then told me that the rear spring had broken, and three tyres were on the limit, and got those done, and they found a worn steering arm bush was worn, got that changed, i said could that cure the noise, they just said time will tell, it was alright for a couple of days and the noise is back, i know this is a hard one to diagnose, just hoping someone as had something similar. any ideas.
Something loose in the boot ?
DSK
CLS 320 CDI, S350 Bluetec
What does the noise sound like? Is it random or only occurring under certain conditions?
Whilst not on a Mercedes, I had a strange one develop no thanks to the damn craters on the M1 road works. Checked the car top to bottom many times over many months to no avail. Then one day got a rubber mallet and gently tapped around the tyres whilst I had my head underneath looking and pulling on stuff. Mine turned out to be the seat/pod thing that the rear spring sits on and its nut was fractionally loose. Symptoms were random metallic rattle as though the car jack was loose in the boot.
stevegbr
stevegbr
The heat shield was tighten funny enough. But did not cure it. Thanks for your input though.
stevegbr
stevegbr
The u
Gearbox rear mount? Assuming it has one.:cool:
The underneath as been checked and nothing found. I know this is project in progress. But you guys might think of something I haven't. Thanks.
stevegbr
stevegbr
I did think of that and emptied the boot. Including the space saver wheel. Thanks for your reply.
