spark plugs clk 55amg
bonez
Recently purchased a used clk55 AMG that is a 2000 model with only 34k miles. There is nothing wrong with her yet but is wondering when i need to be looking at changing the spark plugs....have heard that this is around the 100k mark....great forum by the way
jberks
I thought it was 60k, although there is a 5 year rule too.
Basically, if she gets a bit lumpy on idle swap them out. Otherwise it could be fine for a fair while yet.
996jimbo
C43 estate
I had mine changed on my C43 at around 80k miles, 7 years. They were fine - I just thought it about time.
I think they all last a long time, but there are still different grades of 'long lasting' plugs available.
clive williams
Bonez
I swap mine out in the 500E every 21k mls and clean and reset every 7.5k mls. Even the 4 ground electrode plugs wear (but obviously not as quick). I must admit it horrifies me to think that the spark plugs should be made to last 100k! Having had a spark plug disintigrate in an engine I certainly don't push them further than I have to.
Clive
500E - last of the great V8s
E320CDIT210
angus falconer
London
I had mine changed on the C43 at 55k, 5 years.
A year later had them cleaned up when having problems with MAF, coils and HT leads - precautionary really and as BCS were playing with the ignition anyway it didn't cost much more to whip them out.
At 34k it might be worth having them cleaned and reset but only, as jberks says, if idle is a bit lumpy.
removing V6 plug leads
Just thought that I would mention here, the removal of leads on the 112 V6 and the like. The leads should not be pulled off due to the very high risk of damage to the coil packs, I have mentioned it before. The metal covers on the leads have rings around them, an open ended spanner should be placed between the rings and you lever them off using the rocker cover as a fullcrum point.
Malcolm
jberks
I was hard put to get a finger to them on the 240. No chance with a spanner!
Good advice though, after 2 expensive sets of leads I can testify, they are rather fragile!
B
bonez
Thks guys to all have replied to my post ref spark plugs...car fine with no idle problems...but will get them looked at during the next service which is a B.
CWilloughby
Sparkplugs
:p
I have a CLK230 year 2000 that has only done 28k miles, but have just had the spark plugs replaced as I was told this was necessary as the car is 5 years old.:p
CWilloughby said:
:p
I think that you have been had, plugs are a milage thing, not age.
Malcolm
clive williams
Malcolm
Malcolm, I'm sure the platinum tips have a half-life. :-D :-D :-D
Clive
500E
E320CDIT210
