Special ? gearbox oil
Axcontrols
53 ML 270CDI, 2017 GLA200d
If anyone was following my thread about my ML270CDI auto gearbox (flares when changing 3-to-4) I've just been told that the merc shop have filled the gearbox with "special" oil which I can only drive for 1000 miles after which I have to take it back so they can drain and fill it with the proper stuff ?
Anyone heard of this "special" oil ? Maybe it's some kind of detergent which they hope will clean stuff up and stop it slipping/flaring ?
or what ?
I for one have never heard of that,,and it is not in the MB service / repair info
LYNALL
Kent
I have used both mb oil and atf3/agf3 in mine and both have been fine.
I have just today picked up my car from having gearbox refurbed and he only uses atf3/aqf3 and he reckons he never has any comeback, but once 12 moths warranty up i shall be going back to mb oil.
I reckon they have changed oil and filter and want to do it again with the proper oil, ie they have atf 3 in the moment and once its flushed they will change with mb oil.
Lynall
Xtractorfan
S class
No this is now a fairly standard practise with many MB garages, simply because filling a gearbox with expensive oil and then having to change it later because of contamination//glycol or swarf... can be costly, so many garages now use a cheaper ATF oil, and it flushes out all the old oil and contamination and if the gearbox is working correctly with no problem then drain and refill with proper ATF..
I tend to think it is a good idea..
A
Axcontrols
Anyway - it appears the magic and/or snake oil didn't fix it.
They've changed the 'Valve Chest' plus other bits n bobs for 1100 quid - lucky I didn't need to foot that bill huh?
What would changing the 'valve chest' entail ?
An indie takes £300
A
Axcontrols
Because of the talk about 'special' oil I'm guessing they flushed it, changed oil and filter and then went for a drive to see if that had fixed the problem - when it hadn't they opened it up again and changed the valve chest.
But, as I said, what does changing the valve chest entail ? would the valve chest contain valves that could also be changed ?
