Speed signal for NAV on w203
Status
Not open for further replies.
Hercules
London UK
ML320/2006-w203/2006
Do any forum member knows where is the speed signal to connect a Clarion NVS613 navigation. :shock:
I know there is a signal at the rear of the radio , is that signal good for the navigation unit :?: but I reid on an other forum that the speed signal on the w203 is transmitted on the CANBUS,
if that is correct , do I need to Buy a canbus converter. :?:
Thank in advace for your help :D
piestore
manchester
speed signal
203 speed signal is hard wired to ESP then put out on CAN I shall check to see if there is hard wire signal ( There is on ML (163)) first six digets of chassis no would help
H
Hercules
London UK
Speed signal location on w203
Here are the first six shassis digit No: WDC20300422R07 :D
i HOPE that you can help :?: :?:
piestore
manchester
speed signal 203
checked up today sorry it took so long. bad news no hard speed signal I think you will need a CAN converter
rpalmeida
www.mercupgrades.com
MB have a CAN interface for connecting non MB headunits to CAN cars - it seperates out the signals for speed, lights, reverse, ignition-on
I dont know the part number, the dealers should have it somewhere on their WIS systems I guess - I once saw a document about retrofitting a travelpilot to one of the MB's that listed the part number - perhaps they can search for retrofit and travelpilot and they may find it.
The ML doesnt have CAN, it has discrete signals on the A connector - pin 1 is the speed signal - reverse is on the C connector .
R
piestore
manchester
Can ML
ML does have CAN but there is also a pulse speed signal in the fuse box next to the accelarater pedal
Status
www.ckinsurance.co.uk
