speedometer not working
Petemac
Inverness
merc c250TD 99/2000 150000MILES ON CLOCK GREAT CAR
speedometer is not working sometimes jest driving along and goes back to zero and been automatic cant change gear unless you stop remove key what could be causing this help please the abs light is not coming on so cannot be that
You have lost a speed signal somewhere, without this speed signal the box does not know what to do re changing gear.
We had a post on this a couple of months back and it was a wiring problem, worth doing a search on this.
You have not just changed the radio have you
P
Petemac
Inverness
yes 3 days ago
Then it could be that :D
Unplug the radio and try the car, just the main multi plug, if all OK then cut the wire on pin 1 and all will be fine, or it should be
P
Petemac
Inverness
will try it now once i get the frost off car and get back to you be about 30mins.
P
Petemac
Inverness
speedometer working no problem malcolm went 3mls . last night traveled 1ml speedo stopped 3 times cant thank you enough you have a vast experience behind you and thank you for sharing it with us all the best peter
So pleased all OK very few know this fault, but they do now:D
Whats this fault Malc? Never heard of it myself!!
Its an interesting one and most indies do not know about this :D
The speed signal is used to change the volume of the radio, and this only works with the original radios. If you change the radio, then cut the wire from pin 1, and problem solved
Steve@Avantgarde
Bristol/Somerset
C43 AMG PP/NE, SLR McLaren Roadster, SL55 & C32AMG
Keeping this one in the memory bank for future use!!
Frontstep
T210 320cdi
Well you learn something new every day as they say.
Frontstep
T210 320cdi
Well you can remind me Thursday.
P
Petemac
Inverness
i thing we should vote malcolm in as next prime minister he would sort country out in a couple of weeks he gets my vote
P
Petemac
Inverness
  • #17
speedometer
bad news malcolm speedo stopped 3times 2day on 10 ml trip radio completely disconnected since you told me to do it any more ideas it was fine until the last 2mls once things got warm
I will dig deep and see if I can come up with something
P
Petemac
Inverness
  • #19
cheers malcolm snowing here now
Was the speedo perfect right up to the time the radio was changed
