Speedtronic/power Loss
garry
Do anyone know something about speedtronic problem? For the first this problem was at the first start in the morning after restarting the vehicle it was all ok. Now is on all the time and the car is a slow machine without torque. speedtronic dont work. Thank you for any answer . have replced plugs/coil packs/air flow meter/ HELP ?
G
garry
thank for reply. i have just replced my battery funny you should mention it. the car is e class 200 komp.
Dom320
East Mids.
After my battery was replaced the car needed a 're-set' to clear the fault. Apparently this is not normal, but for some reason my transmission had stuck in 'safe' mode (wouldn't change out of 2nd, or go above 40 mph).
Television might have some other suggestions.
G
garry
speedtronic
thanks for bringing up the battery. i had it checked.
turns out they had put a wrong size battery on.
this seems to have sorted the speedtronic warning .
hopefully. thanks again
