Hope someone can help.
I've got an 04 311CDi which is generally excellent. However recently I noticed on occasions it would seem the engine speed was governed to around 3000rpm. Not that I want to drive at anything over that as I find fuel consumption excellent below that figure.
The vehicle runs smooth and efficiently but a few days ago refused to start after one delivery. Normally it starts at the touch of the key. But this time not. After a few attempts it fired into life and shortly afterwards I had pulled over for a break. At which point I lifted the bonnet and just released the vent on the fuel filter housing just in case there may have been air or even a build up of water. There was a spurt of fuel and the engine cut out. At no point after that would any fuel come through on turning over the engine.
I called out a commercial specialist company and they could get no fuel through either. After being towed to their workshops and theorising the problem was probably the fuel pump. The lines were checked from the tank and all was clear but still no fuel.
They then connected their electronic diagnostic equipment and the thing showed 6 errors. Some of which were apparently old ones. After resetting the fault codes (without actually knowing what they meant as this was not a Merc dealership) my Sprinter started perfectly. That was last Friday. They promised to check the meaning of the error messages and let me know today (Monday). Monday arrives and back to my business of delivering various products to various companies.
The van ran fine for most of the time but once again came to start after a delivery and no go. Eventually got it started and back to the workshop where they once more plugged in their diag unit and revealed 1 error. They are not sure what the codes mean as Mercedes will not help them out with any interpretation. But it does seem fairly certain it is an electrical issue with a sensor or something.
I was just wondering if anyone has experienced anything similar or has an idea to help before I reluctantly re-mortgage and book into a Merc workshop.
Of course the sickener is warranty just expired 1st September.
Sorry it's a bit long winded but hope someone might just have an idea.
