sprinter 311 noisey steering
linny
hi can anybody help i have got a 2000 311 cdi sprinter that has a very noisey steering aloud wushing and swirling noise like when its held in full lock it does this all of the time but sometimes there is no noise when first started up in the morning its just had its m.o.t and the garage did not no what was causing this its not the belt slipping and is realy buging me any ideas thanks
mister_cee333
This may be stating the obvious...but have you checked the power steering fliud level?
L
linny
thanks for that but i have checked the fluid level and it was fine i was told it could be a shuttle valve in the rack thats sticking but not for definate
rickscott
Aberdeenshire
I have had this problem on 2 of our fleet of sprinters, in both cases it was the PAS cooler causing the problem.
disconnect the cooler by removing the hoses from it, and linking them up.
Problem is generally caused by the mounting clips trapping water and rusting through the cooler pipe, strangely it causes the noise by drawing air into the system, although no fluid leaks are apparent.
Hope this helps.
L
linny
thanks for the reply i havnt been on for a while as i had no response i put a new pump on and that was fine for about 2 miles and then it started again so i will disconnect the cooler and see what happens thanks
L
linny
i have disconneted the cooler and it hasnt made any difference stiil as noisey it is doing my head in thanks for that it was worth a try
dava
The Toon
There is valves in both the pump and rack that could cause this noise, however, pull the steering rack boot back abit and see if you can see signs of fluid here. They some times wear and leak very slightly, but also suck air in causing the same symptoms as the cooler.
L
linny
thanks for the replies i have now sorted it i changed the high pressure hose from the pump to the rack and that has done the trick all quite now thanks
mattkh
England
A160 W168 1999 1.6
Well done.
Did you find anything wrong with the high pressure hose ?
Do you think it might have been low on fluid as well ?
