Cnics
- Jan 3, 2007
- Age
- 41
- Location
- Worksop - UK
- Website
- www.cnics.co.uk
Had an issue with the back brakes earlier. Bit of back lane driving (not fast) and use fo the brakes, arrived at a set of traffic lights and was thankful they turned to green and nobody was infront of me, i was throwing it down the box trying to stop, i was stopping from maybe 50mph in a shorter than average distance but FAR from what you would call emergency braking and it is a damn good job as my foot was on the floor and the van was barely braking.
I was only a few hundred yards from where i was going so drove on steadily to there and parked up, noticing the smoke from both back wheels i decided to leave the vehicle in gear rather than using the hand brake when parked.
They were smoking for a good 5 minutes. the Front ones barely warmer than you would expect. Since cooling down things are back to normal and i have a good brake. But of course this is not the issue here!
Its clear i was on the receiving end of brake fade, but the front brakes were barely warm, could i have a problem on the front brakes (ie them not working properly) causing my back brakes to be working so hard, i regularly transport heavy loads and tow trailers aswell, so this is a major concern.
Rob
Rob
