Sprinter fault code p2112
Mathewwills
New Registration
Sprinter 311 2.1 2010
I knew to this page don’t know if anyone’s out this issue before starting to drive me nuts sprinter 311 with 2.1 Engine code 651 Fault code p2112 Throttle valve is jammed closed The Actuator is Blocked blocked- current pending stored I have replaced the throttle valve with new genuine Mercedes one but the fault code does not clear down Even tried leaving the battery disconnected overnight to see if the fault code clears just wondered if some you guys on your way be possible to help me thanks Matt
andrew65b
Sprinter 313 2012
Hi Mathew. I have exactly the same prob on my Sprinter 313 2012. I have also replaced the throttle body with a genuine new one but, despite clearing the error, it immediately returns. Did you get to the bottom of the problem
Tel: 020 8863 9233
