sprinter gearbox whine?
Jamie.W.
2009 Sprinter 311
Hi, new on here and any help would be great. As I go above roughly 3k rpm there is a whine that gets louder and the noise changes to a higher pitch as i go up the revs. Any ideas? Thanks.
Jamie.W.
2009 Sprinter 311
  • #2
Hi im new here and any help would be great, as I go above roughly 3k rpm there is a whine that gets louder and the sound makes a higher pitch as the revs go up too, any ideas? thanks.
Jamie.W.
2009 Sprinter 311
Hi, ive had another look and im pretty sure its a belt pulley bearing, does anyone know roughly how long it will take a garage to fix? Thanks.
clarkmichigan55b
sunny Surrey on a sunny day
Mercedes 208D T1 van 1989
Having not worked on a sprinter it depends which pully bearing is at fault alternator/water pump/PAS pump bearing or idler pully bearing time depends on which one.
Jamie.W.
2009 Sprinter 311
Hi, ye that's true, I just thought because they are all in roughly the same place you know, I guess some are in more of an awkward place to get at. Ill get a stethoscope on it, Thanks for your reply Clark.
M80
Derbyshire
Is yours the om646 engine?
Best I can suggest is to remove the aux belt, with a 17mm star socket and 4mmm pin to hold the tensioner off.
Then work each pulley looking for slap and rumble.
None of this is a big job for a reasonable garage, it doesn't even require an MB Indie.
If you aim to keep the wagon it's best to use quality replacements.
Jamie.W.
2009 Sprinter 311
Hi Martin, yes its the 646, How would I access the benefits of a paid subscription such as reduced price parts from this site? I can see how to do an insurance quote but not parts or labor? Thanks for your earlier reply too.
M80
Derbyshire
I generally do my own work and for parts just I search eBay.
Jamie.W.
2009 Sprinter 311
Hi, yes I was wondering about the benefits of joining this chat forum, it says cheaper rac insurance, parts, labor and some other things if I get the paid subscription. Thanks for your help though.
Call MB Grangemouth, mention the forum and get discount ;)
Jamie.W.
2009 Sprinter 311
Hi Blobcat, ok thanks for your help.
