I noticed after doing a long motorway run after a while of not doingthem that the van got fairly hot at motorway speeds (80-90) by hot i mean at times getting near the next mark up from 80 (typical running temp) on the guage. after stopping and lettingthe van cool down i checked the coolant level and ntoiced it was wellunder the max so i topped itup and the van ran fine and stuck close to 80 all the time for a few days and a few hundred miles when it started to get a bit warm again,some coolant had disappeared again it oppe dit up and everything was normal, again coolant has disappeard after a few days, any dieas what this could be, now hite stuff inthe oil cap area coolant looks fairly normal it has never over heated in the time I have owned it i have ahad a brief look aroudnf or leaks inthe pipes but i can;t see any is there ac hance it could be a slight head gasket leak or do i just need to look harder at the rad and other joints in coolant pipes? I havn't checked the water pump yet, it was changed about 6 months ago, could some of th ebolts onthis come loose and sprung a small leak? I am guessing as its leaking so slowly it is gonna be very veyr hard to detect, any tips on mkaing it easier?
Thanks, Bill
Thanks, Bill
