SprinterPickup
- Jan 18, 2007
Just had a bit of work done with the injector, meaning a lot of things were taken off, cylinder head, cover etc... Since this, I have lost a lot of power and noticed that the oil filler is breathing when i remove the cap (with engine running of course).
I have read somewhere that it may be the breather pipe? What do you lot think?
Also, is it easy to check the breather pipe? Can someone describe where I find this and how I check it?
It has also started to tap from the engine when it gets warm (at higher revs - 2k to 3k rpm), but this may be a completely different problem? im not sure?
cheers
cheers
