sprinter white smoke
betarev3man
wales
hi new member can anybody give me sum advice on my 310d sprinter 97 model.ive put a new turbo on as sum1 suggested this was the problem.this didnt work cleaned the inlet manifold and breathers and egr.the engine sounds perfect hasnt lost any power or used any water as now people are suggesting head gasket.would be most grateful for any help or suggestions as thius vehicle has covered 100.000 miles thanks for ur time:confused:
B
betarev3man
wales
hi thanks 4a reply done oil/filter air filter new glow plugs.run it without intercooler pipes on.havent taking intercooler off tho it looks clean.when u rev it there are traces of oil coming out of the exhaust
Bill312D
****ing hell, thats not too good...long exhaust too...i'm sure dava or someone will come and tell you whats up soon enough.
brandwooddixon
Wolverhampton
S63 Coupe 2014
White smoke may be unburnt diesel, oil will give a bluey tinge but it's often difficult to tell.
Is it definately oil from the exhaust? I've seen "oil" from an exhaust which was actually water with a high carbon content.
Place your hand close to the exhuast pipe so that you can get some one your palm. Give it a good rub. If it's oil you wont see any particles in it, or at least the base colour will be even.
Get the head compression tested.
B
betarev3man
wales
white smoke
thanks guys .done a compression test on in the glow plugs 4 out of five cylinders were close to 600psi.cudnt get to the 5th one as this reading seemed concistant along all 4 .will try to do 5th another day to make sure cheers
mister_cee333
Smoke colours explained (from a website)...
Black smoke
This is due to a air to fuel ratio imbalance, either the fuel system is delivering too much fuel into the engine or there is not enough clean air (oxygen ) a few things to look for :
Faulty injectors (injectors need attention at about 100.000 to 120 000 miles)
Faulty injector pump
Dirty air cleaner
Turbocharger or intercooler faulty
Problems within cylinder head, valves clogged up due to faulty EGR (exhaust gas recycling unit)
White smoke
Normally means that the fuel injected into the cylinder is not burning correctly. The smoke will burn your eyes.
Engine/pump timing out
Fuel starvation to the pump causing the pumps timing not to operate correctly
Low engine compression
Water/petrol in the fuel
Blue smoke
The engine is burning engine oil
Worn cylinders or piston rings
Faulty valves or valve stem seals
Engine over full with engine oil
Faulty injector pump/lift pump allowing engine oil to be mixed with the diesel
Terms and Conditions Site by: Echo Creative Designs © 2004-2007
As one of the symptoms of white smoke is fuel starvation it would be worthwhile to check the inline filter as described here by Dava...
There's an inline fuel filter on the chassis pass side about just back of the pass seat, no one ever changes them, try that first.
B
betarev3man
wales
will try the filter guys didnt no they had an inline one.thanks 4 all your help
FIBAMAN
TYNESIDE
C180,C180,E300TURBO DIESEL
When do you notice the white smoke mostly? If it is worse when you are on overrun you may have worn rings / bores which will drag oil into your cylinders on overrun
dava
The Toon
Check the auto advance on the back of the pump, they seize and will not advance correctly causing ignition at the wrong time, hence white smoke, was quite a common problem. Also the vac pipes that run to it, they split and loose vaccum so it cant pull the advance back, if I remember correctly they rubbed through on the inlet manifold, as it went across the top of the bulk head, also have a look at the wiring harness when your there, as this also rubbed through, wont cause this problem but others another day.
Hope it helps.
PS
If it is seized and I bet it is, free it off with WD.
B
betarev3man
wales
on tickover its fine.when you rev it loads of smoke cheers
B
betarev3man
wales
dava thanks 4 the help .cant beleive all the help you guys have given me merry xmas all.cheers
dava
The Toon
No problems bud, it's amazing , or not, how many take the advice but fail to come back and say thanks, and thats all WE want, no pint's or any thing, just a thanks.
Merry Christmas to you my freind.
If WE can be of help just ask.
B
betarev3man
wales
happy new year
happy new year and thanks for all the help and advice cheers:)
kevgadget
Had the same problem on my 312d resulting in a non mercedes filter not having a non return valve built in, cost me £250 for merc to find the problem for a fuel filter less than a tenner.
B
betarev3man
wales
  • #17
white smoke
hi guys the problem with my van was head gasket gone at the front just behind the camchain.theres an oil well for the hydauli tensioner.cost me £100 for parts .labour me and my cousin done it.resulting in some beers for him.many thanks for all your replies
