Squeaky Auxilary drive belt
Bill312D
Now i'm going to refer to it as the fan belt although i am aware it doesn't drive the fan.
So my fan belt had been aqueeking for a while so i had it changed, the squeek was worse once it was changed, so i took it back, mech said it ws due to abuild up of rubbe rinthe grooves on the idlers etc and he would clean them out for me, said it was done it now only happens on start up....it still squeels all the time! Don;t want to go back again, is there a chance that i can just rectify it by messing with the tension?
B
Bill312D
ha, good question. Sprinter 312D R reg;)
liverbird
merseyside
BE VERY CAREFULL but works for me every time hold a wire brush on the belt with engine running then spray talc powder on belt will fix problem. as long as all pulleys are straigth
B
Bill312D
On the grooved side i take it? got any explanation for this? I don't understand how it sorts it out.
B
Bill312D
OK, will give that a go, gona be hard ot get a brush under that belt though, hav you don this on a Sprinter or just cars?
liverbird
merseyside
Cars mainly but we have done it on vito's but not a sprinter if you cant get at it you might have to take the belt off the spray the talc with the belt on
steve hw
Norwich, Norfolk
Hi Bill312d, i personally would take a look at the pivot. its located at the bottom of the damper and spring. Its common for the bushes inside the pivot to wear out and then wear the pin (securing bolt). . leading to the pivot to not sit level. Or to seize up and no longer move. If you intend to remove / repair yourself be carefull, there is a shim (washer) between the rear of the pivot and the block. Hope this helps steve
