squeaky roof SL55
M
michaelgould
Just purchased an SL55 which I have to say is a fantastic car.....one problem thats driving me nuts.....the roof is very squeaky ( flexing) over uneven ground....is this normal......thanks in advance to anyone who can help
Welcome with your SL55,,its not normal and I will see what info I have later in the day,,you say it creaks but does not knock
M
michaelgould
its not knocking...but a constant flexing/squeaking....much worse over rough ground......thanks for your quick response
BlackC55
South coast
C43
There is a special lubricant available from mb to help stop this. Just rub it on the seals when the roof is half up. I don't have the part number tho.
M
michaelgould
many thanks BlackC55.........i will give it a go
Then to apply this rubber lubricant you need a piece of wood board/plank about 12" long.
Open the roof and stop it when it is a little way open at the front,,place the wood at the top of A pillar on the soft lining and the other end just under the lip on the roof and pull the roof towards the front where it will rest,,the key will chime a few times but just ignore that and remove it.
Like this you can get to every rubber seal on the car
M
michaelgould
many thanks Malcolm.....I shall drop into to my local MB dealer tommorow........it will probably be their only sale of the day !
