Squeal that stops when the brake is pressed
B
BabyBenzBoy
I am having an issue that is the reverse of what most people have - after about 10 minutes of driving a squealing noise comes from the front of the car - when the brake is pressed (hard or light - it doesn't matter)) this stops, as soon as the brake is released it starts again. Does anybody have any idea what might be causing this?
eric242340
Banned
China
Brake squeal
:idea: Look at your front brake discs, do you see a pencil line on either of the discs?
You could have a sticking brake pad or a stuck piston in the calliper, by removing the pads and cleaning out the channels, then applying the correct grease would be the first thing to do.
Malcolm
