Squealing on turns ! (W124)200TE
JohnPoole
Just bought a TE which squeals when using half to full lock whilst turning, anybody else experiencing this or know of possible cause ? with thanks in advance for any advice !
guydewdney
Tring, Herts
www.atct.co.uk
tracking horribly out? power steering fluid very low? Fan belt loose?
give us a clue - wheres the squeeling coming from?
test:-
1) for belt loose. switch ALL electrical things on, inc fans, main beamns, fogs, rear heated screen. does the squeel happen (engine running) yes = loose belt. tighten...
2) for power steering fluid low - check reservoir....
3) for tracking - look at wear on tyres, is it BADLY worn on one edge? yes = go to garage, get tracking done.
marnix
Does it squeals when turning the steering wheel at standstill?
If it doesn't, it's probably worn or badly inflated tyres
paulcallender
Banned
NW
I can't really add much more to guydewdney's post, he seems to have covered all the bases there. One further thing it could be, are you driving it in the style of the 500E's in the film "Taxi"?
smee
alsop worth checking the steering damper which gets worn/dry gives a noise like rubber squeeling
guydewdney
Tring, Herts
www.atct.co.uk
oh - and brake disc dust cover touching disc - my volvo does this sometimes - but its a very metalllic screech, not a rubber screech.
repair - turn steering to extreme lock, pull brake cover (sheet metal thing) away from disc / wheel. turn to opposite lock repeat. you only need to pull it 5mm or so.
