Recently lowered the back seat to transport some waste to the local dump. After re setting the rear seat the SRS dash light came on and will not go out. Can't find any fuses to deal with the system. Any ideas ?
you need some kind of code reader to ask the car which bit of the SRS has triggered the fault. Usually, even if you fix a fault with the SRS on a car it will need resetting.
