SRS light on when someone in passenger seat
JONRW
Kent
It appears that the SRS light comes on every now and again when either the electric passenger seat is moved or maybe if someone sits and moves about in the passenger seat.
I'm assuming that its the pressure pad in the seat.
I've tried looking under the seat to see for a connector that could be loose, which would be a quick fix, but can't find a connector to make it that simple.
Do I assume that this is a job for a specialist ?
star
Reading
Smart + others :)
Just check the yellow plug under the seat,occasionally gets kicked, but normally the seat pad sensor. remove seat and remove seat base cover and replace pad.
