My SRS light on my 2000 E300TD does not go off i have sopken to my mechanic and he says its the N/S SEAT SWOB (SRS) FAULT what is this and where is it located is it a big job?
I have a 2000 C Class and had the same problem. Took it to the garage and apparently there was a wire loose under the front passenger seat. The guy simply fixed it back and the light stopped coming on. Took all of 3 minutes.
Don't know if this would apply to an E class.
