SRS Warning
Brian_M
Ireland
Hi All,
I changed the battery on my C220 (2001) WDB203 during the week.
When I connected the new battery everything worked fine but the computer now puts up the SRS warning as a malfunction. I presume that it's do do with the power having been disconnected.
Does anyone know if there is a way to cancel this warning or would it have to done at a Mercedes dealer.
Regards,
Brian_M
type49
The SRS has detected a voltage fault due to changing the battery with the key still in the ignition. The key must be removed when doing this. You could try disconnecting the battery again (key removed) & leave for 5 mins but it will probably need the fault memory erased.
B
Brian_M
Ireland
Thanks Type49 did as you suggested but the warning remains.
I'll have to take it to a main dealer to get it removed.
Another problem is my air conditioning isn't blowing cold. Had the system re-gassed and checked for leaks. What do you think it's likely to be, and is the MB diagnostics likely to find the fault.
Kind regards,
Brian_M
BlackC55
South coast
C43
I would be looking at the condensor as the problem if you have a leak. Split the rad and condensor apart and look down it with a torch. Look for an oily area at the bottom.
A diag done by a dealer or a specialist and they should find the problem.
B
Brian_M
Ireland
Thanks BlackC55,
Should have said on the last post that there is no leak.
Regards,
Brian_M
wigan,UK
Don't know if your system is the same as the slk but sometimes when the battery has been removed you have to start the car and turn the steering wheel all the way to the left and then right a few times slowly to reset the system for the steering angle :confused:
The air con could be the pressure switch on the receiver/drier try and switch the system on then disconnect the multi plug on the drier to see if the compressor spins if it does but stops after only a few seconds then reconnect the multi plug. if it then stops again it is a faulty pressure switch
hope this helps
Andy Wr
Stoke on Trent
I was just going to say turn the wheel fully lock to lock either 3 or 4 times and it should clear but Peter beat me to it.
type49
This will not effect SRS. This is to repragram the steering angle sensor which is linked to ABS/BAS/ESP warning lights.
Andy Wr
Stoke on Trent
I have actually read this again tonight on an American web site, when disconnecting or replacing the battery .............
type49
Yes you do have to do this to shut off the ABS/BAS/ESP light but the thread says SRS light on.
www.ckinsurance.co.uk
