Hi, I'm having problem when taking off, engine judders and stalls when starting off. Also judders and stalls when accelerator depressed while idling and will not always fire on the button when starting. Has any one experienced this : ANY IDEAS?
Stalling and hard starts, usually combined with erratic ABS light on is caused by a faulty OVP relay which is a common fault. Investigate this if the ABS light has been on.
Otherwise sounds a bit like worn spark plugs, distributor or vacuum leak somewhere. No harm in shelving out £10 for plugs.
Had a look at the MAF SENSOR and it was mucky black so I cleaned it and she is now going like the clappers. I also had out the spark plugs and they definately need replacing I've wire brushed them meantimethanks a mill. StevieA Davie
You lost your key ? Or maybe you need a spare!
Your vehicle imobilliser does not respond anymore?
WE CAN FIX THEM ALL !! Mobile !
Save Time and Increase Profits With us !
