Stange noise from under the car
Issy Hey
New Registration
I have an ML 270 CDi, I have had this car for 16 months, however it was registered in 2001. Over the last few months a strange noise has started, it sounds like it is coming from under the car, it sounds like a rolling ball bearing.
I have taken the car to a garage to be checked out, they tell me that they are not sure what it is , they think that it is something to do with the bearings on one of the front wheels, they do tell me that if they fix this they cannot guarantee that this will resolve the noise, but the car is safe to drive! The noise happens when I turn right or drive around roundabouts, over bumps or down hills.
Can anyone advise?
no they have to work all the time :p
Parrot of Doom
Manchester
I don't see how the angle of the wheels would affect the noise, if it was a bearing problem - unless there was excessive play.
Are you sure that your tyres aren't rubbing against a bit of bodywork?
philharve
Falmouth, Cornwall, United Kingdom
go.to
W202 C230K Auto 2000
Can anyone advise?
Hi Issy Hey
Find an open area and slowly drive the car in a circle as if going around a roundabout. Have someone monitor the sound from outside the vehicle. If you can reproduce the sound, the external observer should be able to locate its origin and possibly its cause.
REGARDS Phil
tom7035
Front wheel bearings are tapered, therefore centrifugal forces cause greater sideways pressures on the bearing surfaces, therefore more noise if worn or 'corrugated'. (Not to be too technical).
bundy
merseyside
mmmmm just a thought. we may be barking up the wrong tree!! wheel bearings tend to make a whine or rumble sound when worn! A ball bearing rolling around noise is the complaint! maybe a piece of cat in the exhaust or that kind of thing :-( hope not.
regards ted
tom7035
Can anyone advise?
You have let the kids out of the boot since your last journey, haven't you? :)
Tel: 020 8863 9233
