STAR communication error
V6Matty
Newark, Nottinghamshire
Well bit of an odd one, EML has come on on my car too now (wife’s 169 is in limp mode for the last couple of weeks but hasn’t moved so not too worried), so I decided to boot up my STAR and after plugging it in I get the attached error message, looks like there is a multiplexer issue but not a clue where to start looking, anyone any ideas?
Craiglxviii
Cambs UK
Do you need a code reader for your Star? ;)
-raj-
Coventry
Multiple R230's & E250 CDI
Did you have a battery charger attached to the car?
V6Matty
V6Matty
Yep, although the batter was sat at 12.8v in position 1 so plenty of charge even before I connected just in case
-raj-
Coventry
Try without the charger attached. I got the same message once and that cured it for some reason.
V6Matty
V6Matty
Tried that this morning, no difference I’m afraid
Malcolm had this on his once. It was a broken wire where it connects to one of the connectors. He resoldered it and it's been good ever since.
Also check you're getting 12v and earth on the OBD2 port.
V6Matty
V6Matty
Never used Star but how good quality are the leads that attach it to the car, if like the old computer lead it dont take a lot to snap a wire
They are heavy duty cables but it’s possible that something is broken
V6Matty
V6Matty
If I had a multi meter that’s my next port of call for checking each of the pins.
Yep 12v at the ODB port, I get the same error on my wife’s car so I’m 99% sure it’s STAR at fault here
Craiglxviii
Cambs UK
I think that’s when he was fiddling with my car!
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
If I had a multi meter that’s my next port of call for checking each of the pins....
An active member for over 12 Years with over 6,600 posts and you don't even have a multimeter in your toolkit...:confused: now that I find beyond bizarre! How have you managed all this time without one?
V6Matty
V6Matty
  • #17
Honestly I’ve never had an issue with electrics where I needed one, plus STAR has been my go to for a long time
