Starting Problems w209
robcomuz
please can you help, i have a mercedes clk 320 w209 a 2003 model, i seem to have an intermittent starting problem, i can turn the key and the car starts straight up and runs fine but if i switch off and then try to start again the engine will not start. It seems i have to wait a good 10 minutes before i can get the car to start, i have had the cam shaft sensor changed and have no fault lights lit or any faults held in the memory. Has anyone had this fault before can you please help. :lol:
rpe2
Silchester
Crankshaft Position Sensor. Won't show a fault. Do a search on here, a common fault.
As rp2 could be the crankshaft sensor, a well know fault
R
robcomuz
thanks for that please can you tell me it is fitted so i can replace it :p
There have been re calls on many new models over this component,,,lets hope that it fixes the fault.
£47 from any Bosch service center or £87 from MB
R
robcomuz
Thanks for the help changes the sensor to day seams to work time will tell
thank you again
